1/2 instument cluster lights work, all bulbs are good
Old Jun 27, 2011 | 08:07 PM
Jerome Casi's Avatar
Car: 1989 Camaro RS
Engine: 355
Transmission: 5 speed Manual
Axle/Gears: Stock
Anyone help me out on this. All the bulbs on the right side of the instrument cluster are not lighting up, (behind the tach, etc etc). There is 4 I believe all around each other that wont light up, but the bulbs are good.
Does the cluster receive power at two different points? Is there some type of distrobution problem in the guage? Anyhelp as to how the guage lights are getting power and why only half are on would be helpful!
Old Jun 27, 2011 | 08:40 PM
Car: 1989 Camaro RS
Engine: 355
Axle/Gears: Stock
Re: 1/2 instument cluster lights work, all bulbs are good
Update, so I took the cluster out, cleaned the contacts I plug it back in, and when the left side is plugged in the lights are working. When I plug the right side plug in the lights come on very dimmly. Barelly on. So each plug is running half the cluster?
Anyhelp on how I can troubleshoot why the instrument gauge lights on the right side are barely coming on?
Old Jul 4, 2011 | 02:51 PM
Car: 1989 Camaro RS
Engine: 355
Axle/Gears: Stock
Anyone? I have the entire dash out. Have checked the wires, nothing is cut etc etc. All fuses are good. All light bulbs are good/grounded. I have no idea what else to check!
Which that much of the cluster not working, is there a way to check the actual cluster ribbon itself?
I have used a continutity tester on each side of the bulbs and ribbon runs and it always beeps telling me there is no break in the ribbons (not sure if this is an accurate way to test).
This car was converted to a Carb setup, previous owner claims someone touched something under the hood and they all started working, but I have played around under the hood and have had no such luck.
Thanks in advance.
Old Jul 4, 2011 | 03:01 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
How does the circuit board routing ribbon look?
Old Jul 4, 2011 | 03:09 PM
Car: 1989 Camaro RS
Engine: 355
Axle/Gears: Stock
It appears to be in good shape. No breaks etc. I have used my continuity tester to check if voltage can pass to all the lights and it can pass signal. Not sure if I should be testing it a different way, when I turn the headlights switch of the gauges all jump and the right turn signal indicator that stays on goes off. I replaced the headlights switch but have had the problems.
Old May 4, 2015 | 08:18 AM
MADMAX350TPI's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: 3:73 Posi
Did this ever get solved? I have the same issue
Old Dec 17, 2018 | 06:48 AM
The Big Hat's Avatar
Car: 89 RS
Engine: 5.7 T.B.I.
Those circuit papers can wear out and create resistance in the circuit. Maybe find another cluster module and swap it out completely. Good luck finding one in good shape. Moisture probably jacked it up, especially if you have leaky t tops.
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
fonzie85
Aug 13, 2015 11:50 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
