Power window switch/connector melted
Old Jun 29, 2011 | 07:25 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Thought i'd Start here for some help on my power windows. I am already replacing carpet so i figured id look at the power window switch while i had easy access. Right before i parked it I went to put the driver side window down and it started to smoke. Needless to say window wont go down and the switch/connector gets hot. Can anyone shed some light on to why it did this and how to fix this? Any help would be great!
Old Jul 1, 2011 | 11:29 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Power window switch/connector melted
a couple things could have caused this - bad connections or a bad motor. a worn out motor usually will draw more power than one in good shape; it may be trying to draw too much amperage for everything else in the circuit and the weak point was at the switch/ connector. the other issue would be a bad connection. if the connection is bad or corroded, you'll have an increase in resistance at that point that will usually result in warm/hot parts.
Old Jul 3, 2011 | 02:20 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Ill look into the connections/ motor, but i can tell you one thing for sure is the motors were absolutely beautiful in regards to how fast they went up/down so i would highly doubt that BUT stranger things have been known to happen. Thanks for the info
Old Aug 19, 2011 | 06:45 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
I know this is an older post but i looked into a bit, it was the ground part that was fried (ground is good) looked at the connection to the motor that to is good. any ideas now?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
