Light for Radiator fan?
Old Jun 30, 2011 | 06:51 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
I just purchased a Flex-a-lite Adjustable Electric Fan Controller,model 31147. I have one on my car now but it was a cheap Auto zone model and it blew out on me. I just needed to know what wire i would splice into in order to run a small light or LED to it. I want the LED to turn on whenever the fan turns on just so i know when im in the car that its on,and that way i can see if it shuts off or not. Im not sure whether id cut into the power wire or not. Does it have constant power running to it? Or would i cut into the small gray wire that runs to the relay?
DylanN
Old Jun 30, 2011 | 07:40 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Light for Radiator fan?
Whatever color the wire that runs from the fan to terminal C on the unit is:
http://www.flex-a-lite.com/auto/31147-99936.pdf
Then, add a ground to the LED.
When the controller sends 12v+ to the fan, 12v+ will also be run to your LED.
Old Jun 30, 2011 | 08:24 PM
Ah i see,THanks alot bro!
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
krisner89
Oct 10, 2015 06:03 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Omega
Aug 10, 2015 12:46 PM
