Voltage changes randomly..
Old Jul 9, 2011 | 11:56 AM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
I'm not sure if it's an alternator problem or a battery problem but in my car when I first start my car the gauge reads right at 13 volts then it will drop down about a quarter way below it and randomly jump back up. At times it even get about a quarter way from 8 volts but never gets into the red zone. Is this normal or should I start looking for a problem? My lights don't dim or anything runs and drives just fine.
Old Jul 9, 2011 | 12:28 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Voltage changes randomly..
it could be a problem with the gauge. get a seperate voltage meter and wire it to the battery and run it inside the car. see if the voltage between the gauge and the seperate voltage meter match up.
Elephantismo
Feb 13, 2019 12:51 AM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
RyanJB
Sep 2, 2015 01:27 PM
