oil pressure gauge hook up
Old Jul 9, 2011 | 11:36 PM
GhostRyCon's Avatar
i have an 87 iroc-z i dropped in a 383 carburated motor, i have the tan wire hooked up to the oil pressure sending unit and it still shoots up past 60 psi when i turn the key. What other step am i forgetting. Do I also need the plug the terminal above the oil filter in, and if so what wires do those hook up to cause i cut all those wires coming from the drive side fire wall...please help thanks
Old Jul 11, 2011 | 04:10 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Slippery Situation
Make sure the sender threads have good contact to the block.
Temporarily clip on a jumper wire from the
tan wire to ground.
Now put the key in the RUN position.
If the oil gage reads zero replace the sender.
If the oil gage still reads high make sure the
tan wire going into the firewall connector has continuity thru both sides.
Then make sure the
tan wire has a good connection in the back of the dash.
If that’s all good your problem is inside the instrument panel; broken trace, defective gage.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jul 11, 2011 | 07:40 PM
GhostRyCon's Avatar
Re: oil pressure gauge hook up
Do I also need the plug that goes to the sensor right above the oil filter on the block connected too.....If so what color wires are they, i think its two wires that make up that terminal
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
