Lights on, wipers stop
Old Aug 10, 2011 | 06:07 AM
Krishan's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0 305 TPI
Transmission: 4-spd Auto
I'm not sure if switching the fuel pump relay with an adjacent relay has anything to do with this
http://www.youtube.com/watch?v=RJrUmZ4sOyg
But just this morning I found out when I turn on my lights the wipers stop.
Can someone explain what is going on in the electronics that causes this and what's at fault?
Are the motors bad or something?
Old Aug 11, 2011 | 11:16 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Lights on, wipers stop
those two circuits are completely independent of each other electricity-wise, but they do come together at the wiper & hi/low switch in the steering column. the only thing I can think of is that somehow this switch broke and contacts are out of place inside. No guarantee, but its a start. Browse through over here, may help if you don't have the factory helms repair manual:
http://www.austinthirdgen.org/index.php?pid=19
Old Aug 11, 2011 | 06:15 PM
Krishan's Avatar
Engine: 5.0 305 TPI
woop. turns out it was a loose ground wire near the front of the chassis
Unscrewed it before to take off another ground wire that kept the secondary radiator fan on..forgot to screw it back on
crazy effect.
dibella989
Sep 1, 2015 04:12 PM
Jae992
Aug 27, 2015 09:07 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
Omega
Aug 10, 2015 12:46 PM
