TEMP Gauge Problems???
Old Aug 14, 2011 | 11:21 AM
RyanWilson's Avatar
Car: 1989 Camaro IROC-Z
Transmission: 4-SPD Auto.
i recently just put my car pack together after leaving it sit in the garage for three, four years.
the temp gauge every time i start the car jumps and pins it self straight up. i removed the bezel so i could push it back down. after doing so gauge works normal, until the next restart?
any suggestions?
Old Aug 16, 2011 | 10:35 PM
CamaroGuy73's Avatar
Re: TEMP Gauge Problems???
I had the same thing happen in my car. I finally removed the bezel, pushed the pin free and then I drilled two tiny holes- one at the top just before where it was sticking, and one at the bottom, where it would also stick. I then installed two small screws in those holes as stops. I put everything back together and you can't see the screws... it did the trick and the gauge works mint.
Old Aug 17, 2011 | 06:50 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Your sender wire is grounding somewhere.
Ghettobird52
Jul 5, 2024 11:18 PM
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
