code 34 help
Old Aug 15, 2011 | 06:55 PM
nutzar4's Avatar
Car: 1988 Pontiac Trans-Am GTA
Engine: 383 stroker tpi
Transmission: 700r4 Transgo full shift kit
Axle/Gears: 2.73* Posi
code 34 help
i have a 1987 trans am gta 5.7fi. It has a code 34(maf g/m to high) and has no accleration, no power. I have checked the maf sensor, both the maf power and burnoff relays and they are both good. It has the stock intake tubing. I checked the wires tht plugged into the computer for the maf and related relays and all are giving voltage to the ecm. help please
Old Aug 15, 2011 | 08:59 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: code 34 help
Have you followed through the FSM diagnostics?
http://www.batee.com/corvette/codes/index.htm
Old Aug 16, 2011 | 07:31 AM
nutzar4's Avatar
Re: code 34 help
No i have never used tht im just using basic diagonistics, plus the codes they are discribing are differtn from the one i am getting on my firebird. In my two service books and the scanner book it says code 34 on my car is maf getting to much air. My idle is smooth at about 500-600rpm timing is perfect and ect. It just has no acceleration at all and when i disconnect the maf sensor no difference and same code(the maf in the car is the chip one) i swapped it with the maf from my other car(that one was the wireone) and it barley ran. So idt the maf sensor is at fault also i swapped the fuel pump and burn off relays with each other to see if the burn off was at fault and nothing happened plus same code.
Old Aug 16, 2011 | 06:08 PM
nutzar4's Avatar
Re: code 34 help
also just bought new maf(wire one) sensor car wont run with it plugged in, i did the whole diagnositcs thing and it told me new maf swapped computers same thing, im gunna replace both maf power and burn off relay and see what happens
Old Aug 19, 2011 | 09:24 AM
nutzar4's Avatar
Re: code 34 help
Anyone have any ideas?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
