lt1 tach signal from pcm vs. direct from coil question
Old Aug 19, 2011 | 01:40 AM
tylerwerrin's Avatar
Hi guys,
I'm running a 1995 camaro lt1 w/ lt1 t56 in my old 1984 Jaguar xj6.
I've been wrestling with figuring out just how to get a tach signal into my tach via the PCM -- I haven't tried just tapping into the wire at the coin and running that wire to the cab yet because A) it's kind of a hassle and b) I already should (in theory) have a filtered tach reading from my PCM. The tach feed is from pin a13 on the red (A) connector.
Is the tach feed from the PCM a logic driven signal (ie, too weak to run the tach) or is it the same feed that i'd be getting from the coil? Im confused because the tach isn't moving AT ALL!
Any illumination would be great,
Tyler W.
Old Aug 19, 2011 | 04:44 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: lt1 tach signal from pcm vs. direct from coil question
The stock tacho is fed direct from the coil,not sure what tacho feed from PCM does
Might get better advise on a LT1 forum
http://www.camaroz28.com/forums/forumdisplay.php?f=9
Old Aug 21, 2011 | 07:36 AM
Pocket's Avatar
Car: 91 Trans Am
You'll have to add a wire on the coil to draw it directly from with the LT1. LT1 cars usually dont have a problem with tach signal, only LS1s in very sensitive tachs. For those use a booster wire and a resistor to bump the signal voltage up. Not real sure how your jag works
Old Sep 12, 2022 | 10:22 AM
Jacques101's Avatar
Car: 1984 &1987 Firebird, 1991 GTA
Engine: 5.0(84) , 5.7L LT1 (87),5.0(91)
Transmission: Automatic
Axle/Gears: 3.23;3.42;2.73
Hi guys,
Tyler W.
Were you able to figure out how to get your tach working?
JeremyNYR
Sep 11, 2008 11:07 AM
Firebat
Jan 5, 2006 05:58 PM
Klortho
Jun 9, 2005 05:19 PM
