LT1 Tachometer
Old May 31, 2005 | 08:35 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
LT1 Tachometer
Ok, I am chasing down the few gremlins left, my tach doesn't work. I have the correct wire spliced into the LT1 harness but no tach. Oil, volts, and temp works.
Also, is there a way to measure the tach signal while the car is running to make sure that the PCM is putting out a signal?
Any ideas?
Thanks for any help
Old Jun 9, 2005 | 03:49 PM
Firebat's Avatar
best way would be to get an electronics buddy with an oscilloscope to see the signal (if any).
if you dont have that --- A cheap $10 voltmeter should tell you if a voltage is there or not if youre just looking to find out if the signal is reaching the tach.
other ideas:double check all your tach connections. make sure no wires cut. if you think your tach is bad - hook it up in another car or if you have a spare tach - hook that up and find out.
more than likely there is a bad connection or cut wire somewhere
Old Jun 9, 2005 | 04:01 PM
Firebat's Avatar
It could also be a bad sensor connection or bad sensor. I cant remember specifically which sensor picks up the tach signal. its probably the one that connects to the optispark.
Old Jun 9, 2005 | 04:12 PM
TexasLT1's Avatar
Car: '92 RS
no "sensor" reads the tach signal, it's taken straight off the coil.
Old Jun 9, 2005 | 04:56 PM
Firebat's Avatar
yeah. wtf was i thinking. check out the coil connection then.
Old Jun 9, 2005 | 05:19 PM
Klortho's Avatar
Car: 1987 GTA
Well, it turned out to be the tach in the cluster, so I just bought a whole new cluster and swapped it out.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
