Battery Drain/Shortage. Need help.
Old Aug 20, 2011 | 08:49 PM
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
I could really use some info on this. Originally I had a 305 TBI, it ran good without a drain, but one day out of nowhere I noticed the car had a drain and would die or not have enough juice to crank (not completely dead) after 1-2 days.
The only thing I've done to it is installed aftermarket radio, installed a set of gauges on the pillar and put in fog lights, and I don't remember which of the changes I did before this started happening. (I don't even know if any of those changes would affect it anyway.)
I just swapped the 305 for a 350 carb. I was hoping with the swap that the battery drain would go away, but it's still draining from 1-2 days.
Last time I checked, the battery worked, the alternator works, I've disconnected the gauges, radio and fog lights but the problem is still there.
Any thoughts?
Old Aug 21, 2011 | 07:21 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: Battery Drain/Shortage. Need help.
Check voltage output on the alternator, if its good do a voltage drop test on,the positivw cable, im banking on the,radio or the fog lights, take the cable off the battery and place one lead on the cable, one on the battery and check amps, minimal draws can add up to kill it quick
Old Aug 21, 2011 | 07:55 PM
Engine: 350 carb
Ok thanks will try it out. What do I need to check out the voltage? A multimeter?
Old Aug 21, 2011 | 09:26 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Correct, set to dc voltage and have a ball
Old Aug 21, 2011 | 10:05 PM
Engine: 350 carb
will try and post updates of whats going on
Old Aug 22, 2011 | 02:37 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
dirty cig lighter sockets n power seats can put on a drain.
Old Aug 22, 2011 | 09:51 AM
Engine: 350 carb
Ok I take a look at that too
Old Aug 23, 2011 | 12:02 AM
b4ccamaro's Avatar
Car: 92 1LE B4C
Transmission: 4L60
Axle/Gears: 4th gen 3.42
What voltage should the alternator be putting out anyway?
Old Aug 23, 2011 | 03:20 AM
gsmarcano's Avatar
Car: Camaro
Engine: 350-Vortec-carbed
Transmission: 700-r4
Axle/Gears: stockola, right now anyhow
had two bad shorts, one the power door lock button stuck "in", and after that the main harness to the engine shorted where it passes through the firewall.
Old Aug 23, 2011 | 03:49 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Before we send this poor guy on a wild hunt lets see what his drain is and then he can idebtify its location using the fuse box.
B4c: 14.4 is the "magic number" it can vary up or down a slight amount depending on the age and condition of the alternator ie worn brushes etc etc
Old Aug 25, 2011 | 04:53 PM
Engine: 350 carb
Wow that must of sucked to fix it.
Ill check the voltage at the alt this weekend if I get a chance
Thanks for all the help ill keep you guys posted on what's going on
Old Aug 25, 2011 | 06:01 PM
Engine: 350 carb
Old Sep 6, 2011 | 09:53 PM
Engine: 350 carb
Ok, had time to check the car this weekend. I checked the wires and taped up and repaired any wires that looked messed up. I also checked the fuses under the dash and the ones further up next to the steering column. I also disconnected the positive cable from the battery and the car stays running.
I guess the alternator still works. Also, I uninstalled my radio, left the battery cables connected and the next day the car was dead.
Are there any other fuses that are around the car that I need to check?
Don't know what my next steps should be. What should I check?
Old Sep 6, 2011 | 10:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Having brain lock on how you do it, but you use a multi meter to watch the battery drain and pull fuses one at a time till it stops.
member fuses in the nose on pass side for fuel pump if its FI.
Old Sep 7, 2011 | 04:45 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Parasitic load test. Pull your fuses one by one and watch your meter youre pretty much stabbing in the dark with what you are doing.
Again forget the wild goose chases, pull your cable off put it your meter to dc amps and put one lead on the post and.the other on the cable, pull each fuse one by one until your original number drops. Do the test first, post your original number (control) and then test it after each fuse is pulled, if the number stays the same then put it back try the next one, repeat until it changes.
Unless you wanna keep trying your current method, thatll take a while tho, just a tip, when somone says try this.... Without seeing the car, theyre working off experience, maybe its that, but the best way to do it is to follow proper testing procedures and diagnose the issue instead of just trying what people tell you
Old Sep 7, 2011 | 07:47 AM
Engine: 350 carb
Ok thank. I guess I need to buy a multi meter and try what blu side. Thanks guy
Old Sep 19, 2011 | 01:58 PM
Engine: 350 carb
Had the battery tested and its bad
Old Sep 22, 2011 | 10:06 AM
Engine: 350 carb
Just got a new battery and car starts right away. I had it connected for 24hs and the battery wasn't dead that's a good sign . I noticed when I start the car the volt meter on the car is between 8 and 12 for he first 45sec to 1min after it stays around 12 and goes to about half way on the gauge . When I turn on the lights,push the brakes and put it in drive it looks like it drops to a little below 12v .
So is that normal or is something wrong ?
Oh and when i disconnect the + cable the car stays running so I don't think the alternater
is bad but I think I'm going to get it check also.
Old Sep 22, 2011 | 10:48 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I was reading this thread and thinking ," sounds like a weak battery to me"
Glad you got it fixed
Old Sep 22, 2011 | 11:21 AM
Engine: 350 carb
Yea I just hope the battery doesn't die in like 3-4 days of it leaves me stuck in a parking lot after work. So will see how it goes for now
Old Sep 26, 2011 | 12:44 PM
Engine: 350 carb
So 4 days later the car still starts without a problem . So I think I fixed it glad it was only the battery
Old Sep 26, 2011 | 02:11 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
But you should of checked it first of all, as most of us assume folks do the simple checks before asking for more help.........
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Numbah-1
Oct 2, 2015 08:27 AM
meeklay812
Oct 1, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
raymondandretti
Sep 27, 2015 06:43 PM
