can i keep my mechanical speedometer and bypass vss?
Old Aug 30, 2011 | 07:58 AM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
I want to me my mechanical speedometer from 89 and bypass vss. I don't want an electronic speedo which the engine and trans I swapped in had. (91 305tpi). I swapped in a mechanical tail housing. I just don't want driveability issues. Thanks.
Old Aug 31, 2011 | 08:41 AM
Re: can i keep my mechanical speedometer and bypass vss?
Bump
Old Aug 31, 2011 | 10:03 PM
Anyone? Please help...
Thanks guys!!!
Old Sep 1, 2011 | 12:46 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I believe the VSS plays a part in determining torque converter lock up, it isn't only for the speedometer.
Old Sep 2, 2011 | 09:48 AM
http://m.summitracing.com/parts/PRF-60116/media
Is this what would be needed to complete swap?
Old Sep 2, 2011 | 10:16 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Your VSS is on the back of the speedo with a cable speedo.
Old Sep 2, 2011 | 11:52 AM
Thanks. I think I finally understand all of this. Ready to tear into it and finish it up. Woohoo!!!
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
sjorgens
Oct 1, 2015 07:54 PM
