engine fan trouble (stays-on)
Old Sep 17, 2011 | 08:18 AM
Guest
Guest
Posts: n/a
Hello everyone, I am from belgium so excuse me for some bad english language please. I own a 91 pontiac firebird 3.1 litre V6. With the ignition on, my fan keeps on turnin even with cold engine, we replaced the relay but that didn't solve the problem since the relay still receives signal from the green/white and brown wire. The complete airco was removed and the connections disgarded, should i bridge some connections ? Even If I remove the temp sensors connections, the problem remains. What fault could there be to the ECM module, the check engine light doesn't indicate a problem. Thank you if you could help me out. Greetings from small Belgium (europe)
Old Sep 18, 2011 | 09:11 PM
Pocket's Avatar
Car: 91 Trans Am
Re: engine fan trouble (stays-on)
First off, welcome from across the pond
Next, figure out what circumstances the fan engages for. EX: does it come on with the key on engine off or only when the engine is running? Start up immediately or does it take a short time to begin?
If it comes on with the key on engine off, then either a previous owner rigged the relay to come on with the IGN or there is a dead short to the dk grn/wht wire
Here is a diagram to begin troubleshooting the problem
http://www.austinthirdgen.org/mkport...an_V6_vinT.jpg
Id begin with a multimeter testing for dead grd from the dk grn/wht wire
Old Sep 19, 2011 | 05:29 AM
Guest
Guest
Posts: n/a
thanks pocket for your quick reply. The fan comes on from the moment the ignition is on, motor doesn't need to run. Alson thanks for the diagram. I will check for dead grd.
greetings from rainy belgium
Old Sep 20, 2011 | 04:06 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fanatical Fan
Ground the dark blue wire that used to go to the AC pressure switch.
Run the cold engine for at least 2 minutes.
Did the fan go off?
Happy Racing!
Maybe I Should Have The Guys Put A Door In The Bottom For Any Roll-Overs In 2012
Old Sep 22, 2011 | 08:49 AM
Guest
Guest
Posts: n/a
I grounded the dark blue wire and took a ride, fan was running al the time, i must keep looking for another cause , could the ECM be defective at the fan output without blinking the check engine light ?
Old Sep 22, 2011 | 03:48 PM
NINÅ's Avatar
Transmission: 765R4
Fanatical Fan
Yes the relay driver in the ECM can be shorted and not throw a code.
Happy Racing!
Spin Me This Week . . . I’ll Spin You Next Week
Old Sep 24, 2011 | 03:27 AM
Guest
Guest
Posts: n/a
I took the car to a garage and had the ECM read out, it seems that the ecm does NOT sends the signal to the relais for action, must be some grounded somewhere else. The powersteering pressure switch is also disgarted should i ground this one too, or not. Any one has the complete schedule for the ecm numbers ? I would try to disconnect the positive wire that comes from the AC command switch (lightgreen/black ?)
Old Sep 24, 2011 | 07:43 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The ECM is the only control for the relay ground, 91 v6.
Old Sep 28, 2011 | 11:11 AM
Guest
Guest
Posts: n/a
I already tried a lot of things, still no solution. I have two connectors hanging loose, can somebody tell me there function (connection) They Come from the same harness as the temperature sensor(single green). There's a round one with a light blue and a lightgreen/black wire and there's one with a green and a black wire. I guess one is from the power steering and the other from the A/C compressor. I don't find the right connections/colours on any shedule. Maybe I should ground or shorten one of these ? Remeber there's no A/C and also the power steering was modified without pressure switch. Thanks
eightsixseven
Dec 16, 2024 01:50 PM
backtothe80s
Sep 5, 2015 12:39 AM
TA8487
Aug 16, 2015 12:21 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
