random wire from harness on fan through fire wall?
Old Sep 17, 2011 | 08:45 PM
SaltLifeCamaro's Avatar
Car: 86' Iroc-Z
Engine: tpi 350 small block
Transmission: a4 :)
Axle/Gears: bone stock for now
just bought an 87 iroc z28, wondering why old owner has a wire running from the harness on the back of the fan to a 50 amp fuse then throught the fire wall. not sure where its running from there. the car over heats unless i am going at a constant speed. i figured water pump or clogged up thermostat. but maybe it has something to do with this wire for the fan. p.s. the fan does not work. anyhelp would be great. i am still trouble shooting this myself. ill update if i find anything else.
Old Sep 18, 2011 | 02:12 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: random wire from harness on fan through fire wall?
probably wired the fun to a switch 12v or similar because it stoped working as its supposed to. follow the wire throught the firewall and see where it goes. test the fan itself and make sure its not burnt out.
youre over heating because you have no working fan....if you havent figured that one out yet.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Sep 2, 2020 07:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
