no electrical power to 89 rs tbi 5 speed
Old Sep 18, 2011 | 05:58 AM
cecain2000's Avatar
I have no electrical power throughtout anything lights, horn, fuel pump, radiator fan, radio , ignition nothing but I have checked power at certain points and it is hot also tried a jumper wire from power off of alternator to the plug on top of alternator and then I have power but I just replaced it two days ago its a reman any other suggestions? Also it does every now and then get the power back and just goes back out as soon as I go to start it I have checked the fusiable links and they look good. I had a shop check it the other day too after I replaced the alternator and then it started to work fine they couldn't find any real reason why it did that. Any help is greatly appreciated.
Update:
I was messing with it and had power again but as soon as i pushed clutch in and turned the key lost everything again but in a few minutes I had power again please help
Update again:
I took the battery and alternator out and had them both tested at O'reillys auto where I purchased them and tested good and I replaced the terminal bolts for the battery now i have electrical power but if i turn on lights kills it then turn them off and in about a minute i have power again but if i try to crank it just kills all the power too so I'm still kinda stuck this far and any help is greatly appreciated I have seen some of the help here and well like to read them and try some of them .
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
InfinityShade
Aug 22, 2015 08:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
novaderrik
Aug 10, 2015 12:44 PM
