83 berlinetta Gauges fuse box wiring
Old Sep 26, 2011 | 05:58 PM
83SilverBerlin's Avatar
Hello all this is my first post!! But any who I just bought my first 1983 Berlinetta and it needs some interior work..I have been trying to figure out why the gauge cluster lights dont work and i have found my problem..here it goes running from the back of the inst LP fuse on the fuse block is a green wire that is just dangling not hooked up to anything i believe that goes to the back of the cluster correct me if im wrong? Does anyone know where that goes on the back of the cluster and will i need to take the cluster out to hook it up or can i get under there from underneath everything?Also all the lights work turn signal indictaor check engine lights etc all work except for the night lights! Help please thank you! its a V6 berlinetta
OR does that green wire go to the light switch?
The Green wire goes to the bottom of the headlight switch/dimmer..Thank you anyway, and for other people who dont know!
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
