1991 Z28 starter problem.
Old Sep 27, 2011 | 09:39 PM
DevonRamos's Avatar
Engine: 305 5.0
When I turn the key the starter doesn't make any noise just basicly doesn't do anything. It used too, but just stopped, any tips?!
Old Sep 27, 2011 | 11:25 PM
NullHead's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Axle/Gears: 3.73, Detroit Trutrac, 10 bolt
Re: 1991 Z28 starter problem.
Check your battery.
Old Sep 28, 2011 | 12:52 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by DevonRamos
When I turn the key the starter doesn't make any noise just basicly doesn't do anything. :
What year?
Could be VATS related
https://www.thirdgen.org/vats_passkey_system
Once you have ruled VATS out
Assuming battery fully charged
Put car in P , park brake on.Connect a wire to Batt POS+ and take it down to the starter
Touch on the starter solenoid terminal.
If starter works and cranks engine over, you have problems with the wiring from key to starter.
Could be ign switch , safety switch on shifter , starter enable relay or the wiring in between
If starter doesn't work then you have problems with starter or the cable from battery ( and connections each end ) or a bad ground cable from engine.
Old Sep 28, 2011 | 05:29 AM
DevonRamos's Avatar
Engine: 305 5.0
The electrical for this car is a mess, wires underneith the steering wheel are hanging everywhere. I will go down the list of what you have said, I'll also upload pictures but that won't be untill Thursday because I have school and work today, thanks for the help.
Old Sep 28, 2011 | 08:22 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
If that is the case and the VATS module can't read the resistor on the key correctly then will give condition you state.
VATS shuts down the starter and fuel.
Sounds like you have some work in front of you.
Old Sep 28, 2011 | 08:42 AM
DevonRamos's Avatar
Engine: 305 5.0
It's a big project. I just changed the fuel filter yesterday because that was the orginal problem, I go to start it, and no noise from the starter, it's a piece of work. So the VATS stops the car from being stolen, so the Vats think the car is being stole, so shut down the fuel and starter?n the fuel pump kicks on when I put the key in.
Old Sep 28, 2011 | 10:07 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Trickier.
VATS stop the computer from making the injectors work
The fuel pump will still run but there is no fuel to engine.
Old Sep 28, 2011 | 12:23 PM
DevonRamos's Avatar
Engine: 305 5.0
Ah, I understand better now. So It stops the injectors, the fuel, and the starter?
Old Oct 1, 2011 | 12:43 PM
DevonRamos's Avatar
Engine: 305 5.0
Got her running! The relay was bad. Whoever had my car before really hacked up the wireing!
Frozer!!!
Jan 19, 2024 04:55 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
deracer
Apr 11, 2016 12:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
