SES light code 12
Old Sep 28, 2011 | 08:29 PM
Kingsnake2005's Avatar
Car: 86 Camaro IROCZ
Engine: Stock 305 with 89 TPI
Transmission: 700R4 w/B&M transpak
SES light code 12
Hello,
I have an 86 Camaro that originally had the computerized Quadrajet. Since then, i have upgraded to an 89 TPI setup with a new custom PROM from tbichips.com. Ever since the swap the SES light will illuminate when there is no problem and go out when there is a problem. E.g. the SES light will be on and if i unplug the wire to set base timing the light goes out, or if i unplug the MAF the light goes out. The light work fine for flashing codes and goes through the normal on off on cycle with key on. If i put the ECM in diagnostic mode- I can watch the engine enter closed loop and monitor rich and lean conditions no problem. But, in normal mode, the light is on- car running fine in closed loop. I was thinking about putting in a relay on the SES wire from the ECM to invert the light when the car is running- so when the ECM provides the ground, the relay would cut the light off, and when the ECM opens the circuit, the relay could turn the light on. I thought i could also wire in a bypass toggle switch and put it on the passenger bolster so i can bypass the relay to read codes etc. What do you guys think?
Old Sep 28, 2011 | 08:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: SES light code 12
Code 12 is no reference pulses from the distributor.
Old Sep 28, 2011 | 08:57 PM
Huh, i thought 12 was the "no problem" code. I converted the harness to a large cap HEI dizzy. could this be my problem? Which wire should i be looking at? I soldered the splices.
Old Sep 28, 2011 | 10:01 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Could be, IIRC, '85 was the only year for the coil in cap distributors for FI (7pin ignition control module).
Code 12 (normal) flashes because while you are running codes, the engine isn't running so, as Aperion stated, no pulses from the distributor, code 12.
Old Sep 28, 2011 | 10:30 PM
Ah, ok. So if the ecm doesn't see the refrence pulses it sets a code 12. So how do you explain the light being off when it should be on? and on when it should be off?
eightsixseven
Dec 16, 2024 01:50 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
GouldyGTR
Aug 21, 2015 10:43 PM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
