power to a painless harness?
Old Sep 29, 2011 | 04:51 PM
frankensteinGTA's Avatar
Car: 89 GTA
Engine: 94 LT1 with Painless Perf. cam kit
Transmission: 700r4 2100 stall conv. Vette servo
what spot in the fuse box would you guys recommend i use for my painless wiring harness "hot" wire? Directions only say to use a slot that is energized when the key is in the start and run position. Swapping a LT1 into a 89GTA. Should i just use the ECM slot seeing as it shouldnt be controling anything?
Old Sep 29, 2011 | 05:45 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: power to a painless harness?
the fusebox has spots for single male spade terminals, the ones labeled BATT are 12v constant. the ones labeles IGN are switched 12v. the ones labeled LPS (or lamps or something like that) are 12v whenever the lights are on.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
sailtexas186548
Aug 24, 2015 10:11 PM
stalkier
Aug 21, 2015 01:54 AM
squiggy2
Aug 9, 2015 09:30 PM
