wiring harness ripping out need help
Old Oct 5, 2011 | 04:22 PM
dabird07's Avatar
Car: 92 firebird
Engine: 305 tpi "stock"
Transmission: slipping
Axle/Gears: 3.42 posi disk brakes!
hjaving problems with this harness for my tbi going tpi so i need new harness so im stripping my motor and come acroos this wireng hooked up and it goes inside the fire wall geuss its hooked up to fuse or dash
second question could i just add tpi wires i need for the tpi opn to my exsiting harness??? thanks
also if right message board can a 87 305 ecm for tpi work on a 92 going to tpi???
if not no big loss gotta for a good deal on this sight
placew iz better then facebook
Old Oct 5, 2011 | 07:57 PM
Pocket's Avatar
Car: 91 Trans Am
Re: wiring harness ripping out need help
First off, leave your dash harness alone. Modifying that will only open up a HUGE mess
Easiest way to do a TPI swap for a 90-92 car is to use a 90-92 TPI harness. An 87 harness can be made to work if the connectors are repinned
Old Oct 5, 2011 | 11:17 PM
dabird07's Avatar
Car: 92 firebird
thnxs for the advice is that too much of a pain to do? if not ill try saves me money
and ecm should still work correct?
Old Oct 6, 2011 | 04:17 PM
Pocket's Avatar
Car: 91 Trans Am
They can be made to work by repinning the 87 harness to 90-92 standards
Old Oct 6, 2011 | 07:14 PM
dabird07's Avatar
Car: 92 firebird
sry for repeat message thanks for info
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
