Turn signal lights not flashing
Old Aug 12, 2010 | 12:33 AM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Hey everyone, for some reason when i turn my turn signals on they dont flash. They do light up but dont flash, i recently replaced all the bulbs with LED bulbs. Could that be the problem? If not what could be?
Old Aug 12, 2010 | 10:23 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Turn signal lights not flashing
LED bulbs probably the issue. You need a different flasher for LED's. A standard flasher works by overloading the bulb with juice, which breaks the connection inside the flasher - this happens over and over, thus the flashing. With LED's, they don't draw enough current to make the flasher break the circuit, thus no flashing.
(OK, not a real technical explaination, but you got what you paid for )
You need an electronic flasher that works from diodes and resistors inside the flasher, and not just a simple circuit overload like a standard flasher. Any auto parts store should have them, about $10 I think.
Old Aug 12, 2010 | 01:43 PM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Thanks ill run to the auto parts store and buy one, ill let you know how it turns out.
Old Aug 13, 2010 | 12:20 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Hey I went to the auto parts store and they didnt have it, then i went to radio shack and they didnt have it. Can you send me a link of what i need.
Old Aug 13, 2010 | 11:05 AM
Car: 1992 RS
Engine: Carbed 350
The Superbright folks say that most of the time these will work, but I've never done it so I won't guarantee it They are on the shelf at autozone, advance, etc.:
http://www.autozone.com/autozone/par...r=6413_0_7281_
If not, then this should definitely work:
http://cgi.ebay.com/ebaymotors/2-pro...ts_Accessories
Old Sep 28, 2011 | 11:26 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
wondering how it turned out and if you have pics
Old Sep 29, 2011 | 12:35 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
I bought an led flasher relay online and everything works great. Lights look awesome!!
Old Oct 7, 2011 | 12:22 AM
Iroc-Z Tone's Avatar
Car: 1985 Camaro Iroc-Z
Engine: 350 5.7 TPI
mine both work but they seem to get tired of blinking after a few seconds! lol. when I put my blinkers on they blink at normal speed then start slowing down until the blinker just stops blinking & stays on. any idea what it could be?
Old Oct 7, 2011 | 12:35 AM
camaro1122's Avatar
Engine: 5.0 LB9 TPI
I would look into replacing the flasher relay under the drivers side dash i believe on the left side. My problem when i changed from the stock bulbs to led was there wasnt enough power since leds are low consumption to get the flasher relay to trip like a circuit breaker. Once the power reach its max it shuts off then since not enough power it turns back on and thats how you get the flashers to work. When i had my stock flasher relay in there it wasnt enough power to trip the relay and therefore it didnt flash. The lights in the dash would freeze, then i got the led relay flasher and everything was good. Take a trip to your local part store and pick one up if you havent tried that. There no more than 10 dollars. Try that and reply if it worked.
Old Oct 7, 2011 | 12:46 AM
Engine: 350 5.7 TPI
alright thanks a lot, I will try that in the morning & get back to you!
Fronzizzle
Mar 18, 2019 08:29 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
