Head lights
Old Oct 6, 2011 | 08:17 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
Head lights
when you turn your high beams on...are all four lights suppose to stay on?
Right now I have one low beam that stays on with high beams on.
thanks
Old Oct 6, 2011 | 10:32 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Head lights
You have a burned out high beam. Your outer pair of lights have a high and a low beam filament, which are not on at the same time.
Old Oct 6, 2011 | 12:32 PM
gscz28's Avatar
Car: 89 iroc
Re: Head lights
both high beams come on...so how can I have a burned out high beam?
Old Oct 6, 2011 | 01:26 PM
Al Hasse's Avatar
Re: Head lights
You have 4 high beam lights, one is burned out. That outer pair of lights are high and low, so you effectively have 4 high beam lights and only 2 low beam. The high beam filament of that one light is burned out. Go get another light from the parts store and replace that one.
Look at the connectors on the backs of your headlights. The inner pair (high beam) only have two pins, one ground and one 12V for high beam. The outer pair (high/low beam) each have 3 contacts, one ground, one 12V for high beam and one 12V for low beam. Working properly, when you switch from low to high, the outer pair of lights are switched from one filament to the other, appearing not to go out...
Old Oct 6, 2011 | 01:40 PM
gscz28's Avatar
Car: 89 iroc
Re: Head lights
thanks Al
I kinda laughed at your reply....what I heard was, do as I say damn it.....just do it. lol
thanks again
Jae992
Aug 27, 2015 09:07 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
