Let's play name that plug!
Old Oct 15, 2011 | 08:03 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Found these 2 a while ago when I went through the car cleaning up the interior- re-discovered the mystery plugs the other day when I swapped in the T5 shifter plate. Photo's are below of 2 plugs. They are mixed in with the wiring for the power window switches. My hatch release button (which may not be the OEM) doesn't match either plug. WTH do they go to?
The one on the left actually has 3 wires- you can barely see the black behind the grey. It also appears the orange wire goes between them both.
THANKS in advance!!!
Old Oct 21, 2011 | 05:59 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Re: Let's play name that plug!
Bump!
The one on the left is for the hatch relay. Still searching for the use for the one on the right.
Old Oct 23, 2011 | 10:09 PM
Motown's Avatar
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Wiper switch? I think all wiring for options were installed, but if the car ended up not getting the option, the wire got tucked away instead.
Just a guess.
Old Oct 24, 2011 | 11:02 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Isn't the rear wiper switch located on the left side of the steering wheel below the fog light switch though?
That's what I always thought too, but over the weekend I looked through an 86 base model at the boneyard that didn't even have a hatch release and saw no wiring. Got me.
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
