ac delete , cooling fan functions
Old Oct 27, 2011 | 08:19 AM
kreator33's Avatar
im deleting the a/c in my car,removing all unwanted wires, it says in the book,that the pressure switch on the ac comp,will ground when pressurizes,connecting the ground in the cooling fan relay,starting it, and then turning it off when pressure lowers , and they say to delete that,tu just ground that wire with common grounds like factory does when not a/c equipped,,,,isnt that going to activate the cooling fan permanently? do i leave the pin in the plugg in and just ground the other end? my brain tells me to unhook and discard,but instruction book tells me to leave there and ground,if its true ,how is it done exactly,and whats gonna keep the cooling fan from being on at all time?please someone explain me how this really works
Old Oct 27, 2011 | 08:33 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ac delete , cooling fan functions
What year?
Old Oct 27, 2011 | 09:00 AM
kreator33's Avatar
the wiring is from an 98 iroc,the computer is from an 89 iroc,car is 86 trans am if that makes any difference
Old Oct 29, 2011 | 09:49 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
'88+, leave the ground open. '87-older, the wire has to be grounded to keep the fan(s) from running full time.
Old Oct 29, 2011 | 11:01 AM
kreator33's Avatar
i meant 87 wiring not 98!
Old Nov 7, 2011 | 06:16 AM
kreator33's Avatar
ok,thanks,i still feel like its gonna be on all the time but i'll take your word and try it i guess
Old Jan 1, 2013 | 01:11 PM
kreator33's Avatar
hey! long time!, if i want to leave the ground open like 88+ ,,, do i just use a computer from 88+ ?? or even, since im having a xhip programmed for what i need,,can i have it working as an 88+ since its the same computer?
gta892000
Aug 11, 2019 11:16 AM
64goatman
Sep 9, 2015 01:09 PM
Silver Spear
South East Region
Sep 8, 2015 12:06 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
