1987 GTA Digital Air Conditioning and Heater Controls
Old Oct 31, 2011 | 01:24 AM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
The fan speeds are not working correctly. I can only get one speed out of it. Sometimes I can get all the speeds. What could be causing this? Is there a resistor pack or relay that has to be changed? This is for a 87 GTA that has a digital dash.
Old Oct 31, 2011 | 10:24 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 1987 GTA Digital Air Conditioning and Heater Controls
not sure if theres a difference with the digital dash, but on the blower housing under the hood, there should be a resistor pack. one for low, one for med low, and one for med high. they have a tendency to corrode and stop working.
Old Oct 31, 2011 | 10:51 AM
Steveh4263's Avatar
Engine: 5.7 LTR
Does anyone with a GTA that has the digital dash know the location of the resistor pack for the heater controls?
Old Oct 31, 2011 | 11:04 AM
travis401's Avatar
Car: 91 Camaro RS
im guessing since the boxes under the hood are the same, itll be in the same spot. its the 4 wire plug on the top of the box. pull the plug, then unbolt the resistor pack
Old Oct 31, 2011 | 10:45 PM
mrrman's Avatar
Can you post a pic where it should be/look like? Thanks
Old Nov 1, 2011 | 01:25 AM
Steveh4263's Avatar
Engine: 5.7 LTR
Old Nov 1, 2011 | 01:41 PM
travis401's Avatar
Car: 91 Camaro RS
there you go...this isnt my car btw, just found on an image search
Attached Thumbnails 1987 GTA Digital Air Conditioning and Heater Controls-blowerresistor.jpg
Old Apr 22, 2012 | 10:45 PM
Steveh4263's Avatar
Engine: 5.7 LTR
Replaced the resistor pack under the hood and I still only get one speed. High speed and no other speeds. I tried two different digital heater controls and the results from both were the same. I could only get the blower motor to run at high speed and no other speeds would work. Sometimes the high speed wouldn't work as well. What could be causing this?
Old Apr 24, 2012 | 10:05 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Speed Demon
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the red wire at the relay assembly, with the key in the RUN position.
When you have the selector on any of the LO speeds is there power on that
red wire?
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
LilHot
South Central
Apr 13, 2026 11:46 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
jackhammer
Aug 15, 2015 10:04 PM
Street Lethal
Aug 14, 2015 08:25 PM
