Engine cuts out when heater and amp are on at same time?
Old Nov 1, 2011 | 03:39 PM
LoganKello's Avatar
Car: Trans Am GTA
If I am running either my heater or my amp seperate, everything is fine, however if I run both my heater while my amp is on, the engine seems to "cut out" very shortly. Any ideas? I assume its electrical
Old Nov 1, 2011 | 03:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Engine cuts out when heater and amp are on at same time?
are you using a capacitor inline with the amp? I bet if you have power windows it would do aswell turn on the amp and operated the window switch. depending on what style accessory brackets you are using 88-92 tbi van and truck high amp alternator will work on 88-92 tbi and tpi car brackets.
Old Nov 1, 2011 | 04:07 PM
LoganKello's Avatar
Car: Trans Am GTA
No I dont have a capacitor, I figured it was probably the alt. it seems that it will only do it with the heat or the amp, everything else works fine together. I guess on the cold days the music will take the back seat. Haha
Old Nov 1, 2011 | 05:28 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
you can get a 1 farad capacitor for cheap and itll be plenty. i had problems with my lights dimming when the bass hit hard untill i put in a cap. still runing a stock alt with it and everything is fine.
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
