VSS wire issues.
Car: '92 Camaro
Engine: '67 327 V8
Axle/Gears: Limited Slip 3.73's
VSS wire issues.
Okay, So i bought this '92 camaro from this guy i know. It has a '67 327 V8, And an '89 IROC Z tranny, The problem is the speedo doesn't work. There is no wire connecting to the tranny, And i can't find that wire for the life of me. I checked around the firewall. I checked all around the tranny. It's no where to be found. Does anyone know where that wire might be? Thanks in advance.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: VSS wire issues.
The 92's speedo is electric (at the trans, the VSS wires, IIRC, would have been purple and yellow). The 89 IROC trans is mechanical and would have required a speedo cable.
My 'guess' is that when the engine was swapped, the ECM was removed, along with the speedo wiring.
EDIT: Check the pic: https://www.thirdgen.org/forums/atta...vss.wiring.jpg
JamesC
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Is this a 700r4 and have you located the vss on the rear tailhousing on the drivers side. Is the ecm still in the car? was this or is this a tbi or tpi car ?
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
