Swapped clusters, lost my turn signal!Help me out
Old Nov 5, 2011 | 12:51 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
I swapped clusters and did an led conversion last night.
At first my temperature gauge and fuel gauge didnt work. As i drove around they all of a sudden started working. So that was weird.
Then i noticed only my driver side turn signal was working.
The driver side lit up on the dash + outside and i heard the clicking as normal.
However my passenger side did not light up in dash or outside and instead all i heard was very slow ticking.
Only the driverside lights up with emergency lights on.
So now i need help narrowing this down.
Could it be the bulb in the turn signal dash slot? I did not replace that bulb with an led, and im not sure if the cluster i bought second hand was working with one.
Would the flasher go out just like that? Where is it located exactly?
I really dont want to mess with the turn signal switch but how can i diagnose it?
Thanks for reading, help appreciated.
Old Nov 7, 2011 | 02:24 PM
Brads RS's Avatar
Re: Swapped clusters, lost my turn signal!Help me out
Did u just put leds in your cluster or did you put led marker/tail lights in?
Old Nov 7, 2011 | 02:28 PM
Car: 1986 Iroc-Z
Engine: 355
Just cluster leds. Im guessing its related to the turn signal bulb maybe i moved it and its not making proper contact.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Fronzizzle
Aug 17, 2015 02:52 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
