92 Firebird not starting, Help please?
Old Nov 3, 2011 | 01:14 AM
wmdgecko's Avatar
Okay so I have a 92 firebird V8 305 TBI and it just randomly stopped starting. When the problem happened, it would have to be cranked quite a bit for it to eventually start, but now it doesnt do anything...just turns in silence without a crank or anything. I took my starter into autozone and they tested it and said it was fine so i then replaced my old battery that was gonna go out anytime. The problem still occurs. My dad and I took a volt meter to the start area and one of the posts that go to the starter is not getting power, so it seems as if the starter is not getting complete power or something. So we believe its an electrical issue and noone i know has knowledge about electrical when it comes to starting issues....Any suggestions?
Old Nov 3, 2011 | 02:49 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 92 Firebird not starting, Help please?
So what is it?
It doesn't crank ( turn ) or it doesn't start ( fire up ).
Two completely different situations ( and problems )
Old Nov 3, 2011 | 05:51 AM
wmdgecko's Avatar
Sorry...the key turns over and everything but makes no sound and doesn't start up
Old Nov 3, 2011 | 01:22 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
disconnect the purple wire from the starter solenoid and have someone turn the key and see if it gets 12v. if it does then use a screw driver to contact between the batery post and the solenoid post on the starter and see if it spins. if it doesnt spin, its either bad, or not getting juice from the battery. if the purple wire isnt getting 12v with the key turned, then you have an electrical issue in the cranking circuit.
btw, when you jump contacts with the screw driver, its gonna spark, so dont be alarmed when it does.
Old Nov 4, 2011 | 04:57 PM
wmdgecko's Avatar
Alright ill try this tomorrow when i get off work, thank you travis. I give details after i test it
Old Nov 4, 2011 | 09:26 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Maybe this can help. Got it out of a 88 Firebird service manual. Should work on a 92 too.
Old Nov 5, 2011 | 04:01 PM
Pocket's Avatar
Car: 91 Trans Am
Most likely blew a fusible link
http://www.austinthirdgen.org/mkport...nE_starter.jpg
The link feeding the IGN switch and fuseblock drive the starter solenoid, so see if you have 12v at either
Old Nov 7, 2011 | 08:21 PM
wmdgecko's Avatar
Aight so my dad and I did what travis suggeseted and when the screwdriver method was performed, it spun. So the starters alright. We then replaced the fusible link on the starter and no luck. It still doesnt start-up, so were thinking its in the wiring somewhere under the dash or the ignition switch. Thanks for the diagrams ill keep them in mind and see if they can help.
Old Nov 8, 2011 | 09:25 AM
travis401's Avatar
Car: 91 Camaro RS
possible the starter enably relay has gone out. its under the driver side kick panel and easy to get to.
Old Dec 5, 2011 | 08:40 PM
GreekMalaka's Avatar
Car: 92 Firebird
Transmission: AUTOMATIC
Hey, I have the same problem. I have a 92 Firebird, 305 engine, automatic transmission. Started having the problem about two years ago and has gotten worse. Started when I would put the key in and turn, nothing would happen. The lights would come on but the starter wouldn't turn. I would wait about 10 minutes and then the car would start. Didn't seem to matter what the weather was like or if the engine was hot or not. Started off doing it about once every two months and now does it about once a week. Replaced the starter about 3 years ago. Have taken it to about 6 mechanics and no one seems to know what the issue is. Plus when I take it in to the shop, it doesn't do it. I love the car but I am going to sell it if I can't figure out the problem. From what I have been reading, a lot of the firebirds have this problem.
Old Dec 6, 2011 | 09:37 AM
travis401's Avatar
Car: 91 Camaro RS
you having to wait 10 min before itll start makes it sound like an intermittent VATS issue, does your security light come on and stay on when it wont start?
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
