brights indicator problem
Old Nov 6, 2011 | 06:21 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
well I was checking all the lights on the car today and I turned the headlights on and noticed the bright indicator was on. I thought my brights where on so I pulled the switch and it went away but then noticed that my brights where on but the indicator wasnt and when the normal lights are on. The indicator is on?
so In short
the indicator is pretty much opposite of what it should be. On=brights off
indicator off=brights on.
Old Nov 9, 2011 | 08:47 PM
mechanic58's Avatar
Car: 1991 Z28 1LE
Engine: LB9 305
Transmission: Borg Warner T-5
Axle/Gears: GM 7.5 3.42 Posi
Re: brights indicator problem
Your description of this problem gave me a headache. Has the car ever been wrecked? Sounds like an idiot hacked your headlight wiring and got it hooked up backwards.
You could just leave it be...and 'know' that when your high beam indicator is on that your low beams are actually on....easy fix brah.
Old Nov 10, 2011 | 10:24 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Do you use a screwdriver to start it?
Old Nov 11, 2011 | 06:54 AM
mechanic58's Avatar
Car: 1991 Z28 1LE
Engine: LB9 305
lmao!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
greenyone
Sep 2, 2015 03:39 PM
