help with trigger wire.
Old Nov 11, 2011 | 08:03 AM
ChevyRS-305's Avatar
Does anyone know how to rigg or "trick" a trigger wire? My alternator isnt charging fully.
Old Nov 11, 2011 | 03:56 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help with trigger wire.
Have you had it tested?
If it is not working then you can't "trick" it into doing anything
Old Nov 11, 2011 | 04:00 PM
Yes i have had it tested. Does the same thing with all the other new alternators on their too. Its a powermate 190amp alternator. I also bought a optima red top and it does the same thing. I also bought a brand new starter and it still does not charge correctly
Old Nov 11, 2011 | 04:48 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
theres always a 1 wire alternator from jegs, summit, etc. just a thought. but there is a way to do what your talking about. possible fire hazard though. are you really willing to risk a fire/problem? it might suck, but find the original problem.
Old Nov 11, 2011 | 04:59 PM
Well it only needs to last till the end of the month when i get my backup car out of the shop and drive it for the winter. Im doing a 383look swap this winter and replacing the whole wiring harness along with it so its not a problem.
Old Nov 11, 2011 | 06:39 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Don't know what style alt that is based on
but in most cases you only need a resistance on a switched 12V feed
to the correct terminal to excite the Alt.
In many cases
just the resistance of the light bulb is enough
Some reading
http://www.alternatorparts.com/cs130_sbpage2.htm
http://www.alternatorparts.com/cs130_sbpage3.htm
Old Nov 12, 2011 | 07:34 AM
Pocket's Avatar
Car: 91 Trans Am
470ohm resistor from radioshack will do the same as the bulb
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
db057
Jan 10, 2020 08:55 PM
Thaney9
Oct 24, 2015 07:26 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
