Wiper wiring help
Old Nov 20, 2011 | 06:50 PM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Transmission: WC T-5
Axle/Gears: 2.77
Wiper wiring help
Im rewiring my wiper motor and both connectors that go to the motor (three wire connector) and the cover connector ( six wires) have all the wires cut. Does anyone have a wiring diagram that will help me hook everything back up, chiltons just doesnt cut it and I can't find anything online.
Old Nov 21, 2011 | 02:52 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Wiper wiring help
http://www.austinthirdgen.org/mkport..._pulse_CD4.jpg
89 uses the same new style pulse wiper motor as the 90-92 posted above. Difference is the C100 pin locations. 89 had them on the engine harness half, 90-92 had it on the light harness half. Doesnt make any difference to you because you're just splicing cut wires
Old Nov 21, 2011 | 08:29 PM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Axle/Gears: 2.77
Thanks for the diagram. So I have three wires that have been cut on these connectors. D & E on the six wire connector, and the black wire on the three wire connector. From the diagram it appears the black wire is just a ground so that ones easy. But the red and dark blue wires (D&E) is a bit of a mystery to me (im not much of an electrician). It looks like they attach to a latching relay of sorts?
Some back story, i replaced my engine harness with new one from tpis but had to cut these three wires to remove the old harness. Am i dead to rights unless i take my steering column apart to re-wire D&E back in?
Old Nov 21, 2011 | 08:59 PM
Pocket's Avatar
Car: 91 Trans Am
Blue and red are washer pump, dont have anything to do with the wipers
Why did you have to cut the harness to get it out?
Why would you have to perform surgery on the column to get the wipers going again?
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Randomtask2
Aug 26, 2015 03:34 PM
eddie jr
Aug 25, 2015 06:52 PM
slade5612
Aug 11, 2015 07:19 PM
