91 gauges in 85
Old Nov 30, 2011 | 06:39 PM
joey 350 LT4's Avatar
Car: 1991 1le 5.7 6 speed
91 gauges in 85
i have 85 firebird and 140 mph gauge cluster from a 91 i need to knw if anyone knws which wires to splice together to make them work i already have the electronic speed sensor on the trany
Old Dec 3, 2011 | 12:34 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 91 gauges in 85
compare this
to this
and go from there
Old Dec 3, 2011 | 05:09 PM
Re: 91 gauges in 85
the diagram for the 91 helps alot is ther anyway u can get the gauge diagram for the 85 because they cut the connectors so i dnt knw what the wires go to
Old Dec 3, 2011 | 05:42 PM
travis401's Avatar
Car: 91 Camaro RS
Re: 91 gauges in 85
if they cut the connectors, then a pin out isnt gonna help you. just go by wire color.
on a side note, youll need a vss buffer box since the vss signal was sent through the ecm on the 91 and then the buffered signal was sent from the ecm to the speedo. a 90-92 305 tbi will have one you can use.
Old Dec 6, 2011 | 09:25 PM
Re: 91 gauges in 85
yea i just trased all my wires with a ohm meter and used the pin out to tell me where to hook them on the gauges still gotta hook up the speedo and when i hook the tach wire up the motor looses fire
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
