Lights stopped working
Old Dec 13, 2011 | 01:13 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
I've had my 83 off the road for a little over a month now and started it up earlier. I noticed that my interior lights stopped working, as did my horn, radio, and headlights/tail lights/markers. I walked away for about 15 minutes and when I came back, my dome light was working again but as soon as I pulled my headlight **** out to test those, the dome light stopped working again. Any ideas?
Side note: Has an aftermarket radio wired in. Has stock steering wheel. Also, last year I had a problem with the gauge fuse shorting ( all gauges and warning lights/buzzers properly working this time) and the problem was the single cruise control wire located under the dash. Just a side note but I figured it couldn't hurt to mention the previous electrical problem.
Thanks guys,
Chris
Old Dec 13, 2011 | 01:18 PM
84z350crate's Avatar
Car: 84 Z28
Re: Lights stopped working
check the fuse under the dash. If you dont have an owners manual to show which fuse it is, check the fuses on the right side of the fuse box, closer to the firewall. The radio, horn, interior lights, and power hatch all run off that same fuse.
Old Dec 13, 2011 | 02:37 PM
BT85's Avatar
Car: 85 Camaro Z28
yea thats gotta be the fuses. My interior lights, radio, and trunk latch were out a week ago and a new fuse did the trick
Old Dec 14, 2011 | 07:09 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The diagram below may be helpful:
https://www.thirdgen.org/forums/elec...ml#post4350355
BTW, check your owner's manual, as 84z suggests, if you have one, for the appropriate diagram.
JamesC
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
zeitghaist
Aug 18, 2015 07:33 AM
Omega
Aug 10, 2015 12:46 PM
