89 camaro rs. Please help car cranks but no spark!!!
Old Dec 20, 2011 | 12:38 PM
zukirider1387's Avatar
Car: 89 Molested Camaro RS
Engine: Dont u wish u knew
Axle/Gears: 4 10s
Ok I have an 89 camaro rs with 305 TBI with a 355 block. All electronics still intact. Ok my problem is I started the car fri when I was at work to go off campus to smoke a cigarette ok then I couldn't get it to start back up. I have replaced the coil 4 times in the past 3 days I've also replaced the ICM twice and the p/u coil. Then changed the whole dizzy all together. Ok power is getting to the coil checked with test light but after that nothing. The power is directing to the dizzy but it won't spark at all. Please help me in any way. I have replaced everything. Brand new parts even a new ecu. Please any ideas o help please my email is bonehead_1387@yahoo.com
Old Dec 20, 2011 | 01:38 PM
85irocinjected's Avatar
Car: 1991 RS
Re: 89 camaro rs. Please help car cranks but no spark!!!
Could possibly be bad crank/cam sensor. If pcm does not get a signal it wont send signal to fire spark.
Old Dec 20, 2011 | 03:19 PM
Axle/Gears: 4 10s
It doesn't have one. That's what others keep telling me but it doesn't have one.
Old Dec 20, 2011 | 03:20 PM
Axle/Gears: 4 10s
Injectors have pulse and everything when trying to crank it just has no spark coming from the coil but coil is def 12v good
Old Dec 20, 2011 | 04:15 PM
Car: 1991 RS
Unplug the pickup connector from the distributor and have someone crank it while you have a plug boot off and see if it sparks.
Also double check all the wires going to the coil. The can get corroded and easily break connection under the sheath of the wire. Try and wiggle it around and see if you get an intermittent connection.
Can also run a ground from your battery to a bolt on the coil to eliminate a bad ground.
Old Dec 20, 2011 | 04:18 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
Did you replace the cap and rotor? (just checkin)
Old Dec 20, 2011 | 08:23 PM
Axle/Gears: 4 10s
Problem solved. Had a bad coil bought from autozone. And had a short from the coil (white wire) for tach cause it ha a splice for aftermarket tach and shift light. It's alive just got to figure out the timing just right and she will b just fine. thank y'all so much for the help and advice
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
antares57
Aug 6, 2015 07:47 AM
