In heaps of trouble. VATS
Old Dec 29, 2011 | 05:10 PM
PetursGTA's Avatar
Hi guys.
To make a long story short. Bought a 1988 Trans Am GTA. It doesn´t crank or give fuel.
Of course I thought it was the classic resistance issue and bought the stuff needed. Looked for the "orange" wire coat in the steering column but could not find.
Found some modules/control boxes and some cut and spliced wires. Anyways, took some pics.
Can anyone please tell me what's on these pics.
Please help me
Old Dec 29, 2011 | 05:15 PM
PetursGTA's Avatar
Re: In heaps of trouble. VATS
Where is the orange coat with the two white wires inside to put new resistance in???
Old Dec 29, 2011 | 05:29 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
looks like a old alarm system, maybe a vats modulator box? lunch money !!! and the orange wires you are asking about are in the bottom picture with the picture with the heat shrink on them.
Old Dec 29, 2011 | 05:30 PM
PetursGTA's Avatar
Thanks! But it looks like they've already been modified in some way. Should I try cutting them and putting the resistance there?
Old Dec 29, 2011 | 05:32 PM
Engine: Lb9
Transmission: M20
is that small box hooked into the ecm with the brown wire going to the blue ecm vats signal ?
Old Dec 29, 2011 | 05:33 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
If you can't figure it out, this worked perfectly for me.
http://www.mamotorworks.com/corvette...-1-58-863.html
Old Dec 29, 2011 | 05:34 PM
PetursGTA's Avatar
Yes. If I remember correctly.
Old Dec 29, 2011 | 05:37 PM
PetursGTA's Avatar
Thanks! This could help. But only If I know what previous modifications are? Don't know what's been done already.
Old Dec 29, 2011 | 05:41 PM
Engine: Lb9
Transmission: M20
that is how it is bypassed than. There are 3 ways to bypass the vats memcal reprogramming, a modulator or measuring the resistance in the key and installing the correct resistance across the orange wires.check the power and ground of your modulator, vats was in some 88 and all 89 up.
http://www.ebay.com/itm/GM-VATS-PASS...ht_3637wt_1055
Old Dec 29, 2011 | 05:54 PM
PetursGTA's Avatar
Thanks.
I measured the resistance in the key and it reads 630. Bought the resistance but could not locate the orange wires until you pointed them out.
Do you think it will work the simple way although it's already been modified?
Old Dec 29, 2011 | 05:57 PM
Engine: Lb9
Transmission: M20
if the passkey module is still there and working that yes that bypass will work you would want too disconnect the modulator box.
Old Dec 29, 2011 | 06:08 PM
PetursGTA's Avatar
Thanks alot!
One (two) more question:
The module on the first picture, is it the ECM?
Why have wires been cut from it?
Old Dec 29, 2011 | 06:10 PM
Engine: Lb9
Transmission: M20
first picture looks like a old alarm system
Old Jan 2, 2012 | 03:04 PM
PetursGTA's Avatar
I cut the alarm system out. Now trying to rewire everything.
But why does my key read .630 ?? I can't find that as a valid pellet resistance. Doesn't fit to any of the 15 key codes.
The old alarm system was hooked to a flip switch and a small button in the dash. Can anyone tell me why??
Thanks, Peter.
Old Jan 2, 2012 | 08:53 PM
Engine: Lb9
Transmission: M20
The flip switch was more than likely a select switch for modes in the alarm and the switch was a reset.
https://www.thirdgen.org/vats_passkey_system
Old Jan 3, 2012 | 08:30 AM
PetursGTA's Avatar
Ok, but why does my key read .630 ohms? That doesn't fit any pellet value.
Was it pellet 3 originially and somehow faded?? Sorry for stupid question. Just getting confused.
How do I know the correct ohm value that the passkey module keeps?
Old Jan 3, 2012 | 11:33 AM
Engine: Lb9
Transmission: M20
I'm not sure why the resistance on your key is .630 but looks like you need to start within the #3 range and see if you can get it too bypass and maybe try within the #2 range if that fails.
Old Jan 3, 2012 | 11:42 AM
znate's Avatar
Car: 87 iroc
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.73 posi
just buy the bypass box and dont worry bout it anymore its easy to hook up and never have to fool with it anymore its like 40 bucks for the daul switch thats what i done when i swapped a 92 305 tpi in a 88 i had. i sold the car or i would show you some pics of it.
Old Jan 3, 2012 | 10:26 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
maybe the key is the wrong one to start with
Old Jan 4, 2012 | 11:47 AM
PetursGTA's Avatar
Thanks guys. I appreciate this.
Still wondering, everyone talks about white wires to solder the resistance to. In my case the wires are yellow.... Anyone know why?
Peter.
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Winchester1094
Sep 15, 2015 09:48 AM
