de aircon q's
Old Dec 30, 2011 | 11:24 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
de aircon q's
Hi, im trying to work out why my fan has decided to stay on all the time although i am now wondering if it has always been on since i took the aircon out and hadnt noticied, i had this on a jeep and wondered if it has hapened again ?
is there an aircon wire/conector/switch that tells the car to switch the fan on that i need to sort ?
Anthony
Old Dec 30, 2011 | 12:08 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: de aircon q's
I removed all my a/c and just disconnected all the wires and the fan doesn't stay on. The wires are all just fastened up so they don't hang down. How are your a/c controls set?
Old Dec 30, 2011 | 04:34 PM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: de aircon q's
ok thanks, im not going mad then ! i guess ill change out the temp sender and see what happens
thanks
Anthony
oh happy new year !
Old Dec 30, 2011 | 05:01 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: de aircon q's
Your a/c circuit signal is normally closed when off. You probably clipped or disconnected a ground wire and doing that makes the a/c think the compressor is running so it turns on the fan.
Old Dec 30, 2011 | 05:39 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: de aircon q's
Find the connector that was attached to the switch on the A/C line running down the passenger's side frame rail. Cut it off, splice the 2 wires together, cover with either heat shrink tubing or electrical tape, and put back into the harness. No more fan running all the time.
Old Jan 1, 2012 | 11:40 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: de aircon q's
Originally Posted by zs&tas
... im not going mad ...
Owning a third gen can make you go mad but not this time! Happy New Year.
bigmacnz
Dec 2, 2009 09:43 AM
AussieGTA
Jul 28, 2004 04:54 AM
powermite
Jan 15, 2004 01:00 AM
ninja
Nov 28, 2002 07:11 AM
SIMON HOLTBY
Aug 7, 2002 02:26 PM
