dimmer switch replacement
Old Jan 9, 2012 | 06:01 PM
jiyasa's Avatar
Has anyone here replaced their dimmer switch in the steering column? What is involved in doing this? Is it an all day job or fairly simple to do? Thanks in advance
Old Jan 9, 2012 | 07:02 PM
ex-x-fire's Avatar
Re: dimmer switch replacement
Its not bad to do, its at the base of the column. The holes are slotted for adjustability. Make sure the rod doesn't unhook at the lever area.
Old Jan 10, 2012 | 02:00 PM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
Its not bad at all. The worse part is getting the 2 screws holding it in...out. Not bad though. I just did one and was going to wait for my husband to get home to do it but ended up doing it myself in about an hour or so and I wasnt hurrying.
Old Jan 12, 2012 | 02:09 PM
jiyasa's Avatar
Okay, thanks guys. I wasn't sure what all would be involved, I just have no brights and it's getting foggy here at night. Thanks again
Old Jan 13, 2012 | 12:31 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
brights and fog dont mix, just fyi.....the fog just reflects the bright light right back in your face.
Old Jan 13, 2012 | 12:44 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
You may not need to replace the switch, it could just need adjustment. If you can push in on the front of the switch where the rod goes and click back and forth between highs and lows you just need to loosen the screws and take up the slack for the rod to work properly
Old Jan 13, 2012 | 11:34 PM
jiyasa's Avatar
Thank you, Henry. I'll have to try that in case I don't need a new one. Lot of deer out here at night and I have a $800 bumper on my car that I can't replace. Thanks guys.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Dkelz313
Apr 7, 2016 10:38 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Fronzizzle
Aug 9, 2015 01:15 PM
