Location of stock wiring
Old Jan 17, 2012 | 10:32 AM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Im putting back the all the stock wiring after an engine swap, except all the fuel injection stuff. Problem is, i need to know the route of the wiring on the car.
Main things I need to know, are:
Where does the junction block in pic 1 locate?
Whats the route of the cable to the alternator in pic 2
Whats the route of the cables to the starter in pic 3
Attached Thumbnails Location of stock wiring-dscf0117a.jpg   Location of stock wiring-dscf0118a.jpg   Location of stock wiring-dscf0119a.jpg
Old Jan 17, 2012 | 11:21 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
Re: Location of stock wiring
The power block goes on the passanger side of the rad where the fan relay goes
The alt cable depends on what style you have. Vblet (passanger side alt mount) is straight up from the frame rail. serp system, Driver side mount, need to confirm, but does it go straight across the motor?
Starter wires can go one of three ways depending on length. The first is along the frame rail down the k member, hugging the motor to the starter, second is down the back of the motor to the starter, or the third is along the intake down the front of the motor to the k member, then back to the starter hugging the block. Believe the last way is the normal TPI way with a serp system.
Old Jan 17, 2012 | 01:26 PM
Car: '92 RS Camaro
Transmission: TH400
Its a serpentine set up. Have ya got any pictures?
Old Jan 17, 2012 | 01:36 PM
Car: '92 RS Camaro
Transmission: TH400
The reason Im asking, is all the wiring was pulled to one side when the old motor came out, I did have some pics, but cant find them? The wiring doesnt seem long enough to where I thought it would go
Old Jan 17, 2012 | 02:56 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
I dont have any picks as mine is a v belt setup ('86). I have an 89 harness that I plan to put in the car with a serp setup. The starter wires go from the c100 across the back of the motor, to the front of the motor, then down the front hugging the block to the starter. In there there are also the knock and one other wire (you dont need those for a carb setup).
As for the power block, it is on the side of the rad beside the battery on the passanger side. I will see if I can dig up a picture.
Old Jan 17, 2012 | 03:04 PM
hrspwr's Avatar
Car: 86 IROC
Axle/Gears: BW 3.27
Double post.
Jeremys87
Jul 14, 2022 09:08 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
marcusaw
Aug 10, 2015 08:13 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
stalkier
Aug 7, 2015 04:49 AM
