Fog Lights not working
Old Jan 13, 2012 | 02:56 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
The fog lights in my car are not working. I put a test light on the pigtails to the fog lights and both wires have power to them. What should I look for to fix what ever is wrong?
Old Jan 16, 2012 | 05:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Driving In London
If the test light illuminates when you are testing with both probes in the socket (not one in and the other on ground) either the connector(s) are dirty or the lamp(s) are burned out.
Happy Racing!
Maybe I Should Have The Guys Put A Door In The Bottom For Any Roll-Overs In 2012
Old Jan 16, 2012 | 07:02 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Fog Lights not working
I was testing them by hooking the test light clamp to ground, and placing the test light probe into each of the pins in the connector, one at a time. Is this not correct? It had power at both pins, and the bulbs appear to be good.
Old Jan 16, 2012 | 11:30 PM
ROADHAMMER86's Avatar
Car: 1986 Chevy IROC-Z
Engine: 5.0 305
Transmission: 5- Speed
i have the same problem i currently have the factory switch disconnected cause i had some smoke coming from the top of the dash and top vents
Old Jan 17, 2012 | 04:56 PM
NINÅ's Avatar
Transmission: 765R4
Testing… Testing… Is This Thing On ?
The problem testing it that way is the sockets might have bad ground connections therefore you might be bypassing the problem by not probing the sockets.
Happy Racing!
jaridjohn
Jul 8, 2024 03:49 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
