custom led headlights
Old Jan 18, 2012 | 09:49 AM
tcassaday's Avatar
Car: 87 Firebird and 93 Accord
Engine: Bird has a 355 ready to be put in
Transmission: TH-350
Axle/Gears: stock 3.43
I have plans to make a custom front bumper for my bird which entails me using the top of a bird bumper and the bottom of a cam bumper. The is a photoshop ive seen of what it should look like.Name:  bumper_chop.jpg
I want to get rid of the flip ups though and blend them into the hood. In the slits right there where the turn signals are i want to make some custom leds for the headlights and turn signals. how would i go about doing this. i have an idea but i dont do too much electronic work.
Old Jan 18, 2012 | 11:47 AM
85irocinjected's Avatar
Car: 1991 RS
Re: custom led headlights
Your going to need some high power Luxeons and good drivers with a bit of cooling if you want it to be any good. Here is Audi's LED setup. That would be really nice to emulate. http://www.worldcarfans.com/10708133...-with-r8-model
If you don't have experience with lighting circuits then this project may be over your head. Practice with some basic 5mm bright white leds to get the circuits correct before you try the more expensive high power stuff. Don't expect to get a good headlight by just using a bunch of 5mm LEDs.
Old Jan 19, 2012 | 08:34 AM
tcassaday's Avatar
I just got done with the electrical course at Lincoln Tech for the auto tech program so i know a little bit. Where could i buy the parts for this build.
Old Jan 20, 2012 | 11:28 AM
Car: 1991 RS
Search around for the best price on the LEDs and you can get everything else from Mouser, Digi-key, Octopart, etc...
Definitely post progress pics during this build. I would like to see how it turns out. I thought about doing some LED headlights but don't want to mess around with that idea right now.
Just remember along with adequate power your going to need some good cooling for those LEDs also. In my slightly higher power LEDs projects I run CPU heat sinks with 80mm fans for cooling each LED. But I have a bit more space than you are going to be constrained to..
Old Jan 23, 2012 | 09:30 AM
tcassaday's Avatar
thanks for the help
Fronzizzle
Feb 9, 2017 09:31 AM
Nervous2
Oct 8, 2015 10:53 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
