car owners with car alarms...help me
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
ok so heres the deal i got this remote start/alarm system im putting in myself bc im done with the shops bs run arounds and can nots. anywaz ive pretty much got it figured out how to wire everything BUT i do not now where to put the shock sensor or brain box at. so if anyone whos had theirs installed can you tell me please where these items are on your car. thanks a lot for the help.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: car owners with car alarms...help me
Well, with yours being a 92, you can't put the brain where I put mine (where the VATS module is under the dash). All I can tell you is that my shock sensor is mounted to the dash bracket just to the left of the steering column. If you're going to run a hatch pop anyways, you WILL need to install a relay to control it (seems dumb, a relay to control a relay, but the switch is the way it is), so you might as well dig out your dash and harness and start finding places to connect to.
mustangman65_79
Aug 11, 2015 03:17 PM
3rdgenparts
Aug 6, 2015 09:03 AM
