Electronic help
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
Electronic help
When i turn the key in my 88 305 tbi 5 speed camaro the engine tirns but theres no fuel from the injectirs... The jet cables where cut and i just twisted them back... While playing with them some toutched the block and the fuel worked... Im wondering if i forgot to connect the ground... Where are the grounds located?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Injection Perfection
They are grounded VIA the injection control electronics.
The wires leading to the aforementioned are supposed to be contained in the injector connectors.
The left injector connector electronic grounding wire is green.
The right injector connector electronic grounding wire is blue.
Happy Racing!
I Didn’t Jump The Start, The Flagman Was Late
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
MrPackstin
Oct 25, 2017 08:09 PM
gta892000
Sep 16, 2015 12:37 AM
