88 350 fan switch
Old Jan 28, 2012 | 10:34 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
88 350 fan switch
I was wondering where is the fan switch located on a stock l98 tpi 350 also where is the fan relay the dual fans do not kick on when the temp reaches passed 220 degrees.
Old Jan 28, 2012 | 06:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 88 350 fan switch
computer turns on fans at programmed temps which in most cases is closer to 230F
(and your temp gauge may not be that accurate anyway)
Do fans run when you turn A/c on? ( at any engine temp )
Old Jan 28, 2012 | 07:42 PM
Engine: LR4 4.8
I thought there was a fan switch on the L98 is there a relay to turn the fans on cause In every magazine I look there are aftermarket low temp fan switches to replace the stock hi temp one
Old Jan 28, 2012 | 07:52 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
There is a temp sensor/fan switch in the passenger side cylinder head. I broke mine and replaced it with a generic one from advance auto parts. Worked like a charm.
http://shop.advanceautoparts.com/web...|GRP2061A_____
Old Jan 28, 2012 | 07:56 PM
Engine: LR4 4.8
Ook thanks alot also I notice that the single wire burnt up from sitting on the header does the switch come with a new wire connector as well. An for my last question which relay is it over by the radiator for the fan so I can replace that as well so I can get these fans to come on
Old Jan 28, 2012 | 08:52 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
I had to trace the wire back from the sensor to the relay to get the right one. I believe the hypertech switch (it brings the fans on at a cooler temp) comes with a connector that you just crimp on. Or if you want to use the original sensor/switch you can replace it with a new one
http://tpiparts.net/inc/sdetail/10962/772
Old Jan 28, 2012 | 09:34 PM
Engine: LR4 4.8
If not I'll just cut it off my donor car an crimp the wires an connector Thanks for the info on where it is located
eightsixseven
Dec 16, 2024 01:50 PM
MustangBeater20
Oct 29, 2022 09:20 PM
RazorN8
Jan 7, 2022 11:44 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
