VATS need help!
Old Feb 4, 2012 | 03:13 PM
VandykeT/A's Avatar
VATS need help!
What I'm working on is a 2000 SS. Well what happened was my stock steering column screwed up so I bought one off ebay. It was suppose to be a manual column but the sent an auto. Anyway I put it in and as expected the car won't start. So I get the right resistors to make the 887 number 4 key. Well the car fired right up and ran. Well I turned the car off and it wouldn't start back. I pushed on the resistor and it fired back to life but wouldn't start back so I decided I would just cut the wires the next morning and splice it in that way. Well now the car won't do anything. I've tried 4 sets of resistors (took 2 to make the 887), I dried them with a cig lighter thinking they may have got wet from rain, I've let it sit, unhooked the battery. Is it possible its because I actually cut into the wires? Thanks
Old Feb 4, 2012 | 11:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: VATS need help!
So I get the right resistors to make the number 4 key............
As far as I am aware if the car has a CCM /BCM ( which I assume a 2000 model has ) then the resistor trick doesn't work.
You would have to put your old key barrel into the new column to use your correct old key or get a new #4 key blank cut to suit the lock in new column
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
