ignition problems!!!! PLEASE HELP!!
Old Feb 7, 2012 | 11:57 PM
Chris_89rs's Avatar
Car: 89 Camaro R.S.
Engine: LB9 5.0 (lt1 cam)full exhaust..
Transmission: WC T-5 pro5.0 shifter zoom S/s
Axle/Gears: 9 bolt, 3.27's
(before this everything was working fine)I was working on getting my high beam rod back on that little plastic piece. when I touched the rod with needle nose pliers i hit the turn signal lever and that created a spark everything cut off and came back on and right after that my wipers, brake lights, and car charger (cig lighter) stopped working.
I replaced the fuses and everything works fine, however now my car won't start with the key, I had a push start ignition installed a while back, so i connected it and placed my key in the on position and it fired right up???
What could be causing my key to not work????
any help would be great
thanks!
Old Feb 12, 2012 | 05:00 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: ignition problems!!!! PLEASE HELP!!
thanks!
this is EXACTLY why we always disconnect the neg. bat. cable BEFORE we repair anything remotely electrical. anyway you may have shorted out your ign.switch,try another
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
