speedomiter tachomiter trouble
Old Feb 14, 2012 | 11:16 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Have a 90rs that I got.had a dead engine.had 90 bird that was rearended.I took the 3.4 block, 700r4tranny, driveshaft, engine, harness ,ecm,rearend,gastank,all canisters radiator,and put them in this camaro.Got the engine running and driveing great.BUT the speedomiter and tac dont work.tach pegs out and speed dosnt do anything.I've looked at the dash asembly out of the bird.after reading the book and comparing pics they show a vss mounted on the cluster back.the bird one dosnt have these.I havnt taken out the rs cluster yet.I was told there is a part for the tach thats gota be changed.it had a 305tbi in it.now im a 3.1 map system.I didnt do a thing to the engine and tranny.the birds gagues worked great.any clue if the two systems are not compatable?here some pics from the dead bird.
Attached Thumbnails speedomiter tachomiter trouble-0214122235.jpg   speedomiter tachomiter trouble-0214122241.jpg   speedomiter tachomiter trouble-0214122237.jpg
Old Feb 15, 2012 | 07:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedomiter tachomiter trouble
The VSS is mounted on the cluster in cars with mechanical speedos, on the tailshift with electronic speedos.
JamesC
Old Feb 15, 2012 | 04:55 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
thankyou.
Old Feb 18, 2012 | 04:45 PM
Bobby Suth's Avatar
Axle/Gears: 273?277
I've tried 3 diferent gauge clusters and another vss on the tranny.car runs great.still no speedo.Where is the senser for the tach I gota change.cant figure it out.Firebird and camaro arnt different are they?any way to test the wires from the ecm to the gauge cluster to make sure its good.all other gauges good.Not any chance the speedo and tach would be switched around?tach peged out speedo dead!
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
