Oil,Tach and Fuel Gauges Fluctuate with acceleration???
Old Feb 19, 2012 | 03:02 PM
rs91guy's Avatar
Car: 91 z28
Engine: 5.7 350 TPI
Axle/Gears: 3:23
Oil,Tach and Fuel Gauges Fluctuate with acceleration????
my 91 z28 has this issue at idle tach is running at 2800 or so and my fuel,oil pressure gauges go up when a accelerate for example if i nail the gas fuel guage goes to full and oil pressure goes to max.and during reg driving oil guage jumps all over the place and fuel gauge returns to actual reading at idle. im figuring its a ground issue but i figured if anyone knew this would be the place to ask. i put a ton of money and time in this car, i love it and would like to get the gauges back to normal any help?
Old Feb 19, 2012 | 08:06 PM
Seafarer12's Avatar
Car: 92 GMC K2500 LD
Engine: 350 TBI with some mods
Transmission: NV4500
Re: Oil,Tach and Fuel Gauges Fluctuate with acceleration???
Do any of your lights get brighter when you gun it? Might see what kind of voltage your running when you gun it.
Old Feb 19, 2012 | 09:13 PM
rs91guy's Avatar
Car: 91 z28
Engine: 5.7 350 TPI
Axle/Gears: 3:23
My lights get a little brighter when i give it gas
Old Feb 19, 2012 | 10:39 PM
Seafarer12's Avatar
I would get a voltmeter from someone and check the voltage when you gas it. If you can't get one unplug your alternator and see if it still does it when you gas it. I bet your voltage regulator took a dump and it is running full voltage to your field. When you gas it instead of holding your voltage at 14 volts it is letting it pump out as much as it can. If it is running high you either need to put a new voltage regulator in your alternator or get a new alternator. Running high voltage can do damage to your car.
Old Feb 20, 2012 | 07:40 AM
rs91guy's Avatar
Car: 91 z28
Engine: 5.7 350 TPI
Axle/Gears: 3:23
A buddy of mine parts these cars out so i may just swap alternators real quick n see if that does it
Old Feb 20, 2012 | 10:21 AM
Seafarer12's Avatar
I would unplug the alternator first and see if it stops. It would save you extra work incase it isn't the problem.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
bamaboy0323
Aug 15, 2015 07:20 AM
