rewiring headlights?
Old Feb 20, 2012 | 10:02 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
i read somewhere on here that you can wire your headlights so that when you have your low beams on, all 4 headlights are on, and when you turn on your brights all four headlights go bright, can someone direct me towards that link or tell me how to do this? thank you
Old Feb 20, 2012 | 12:48 PM
Engine: L31 350
Re: rewiring headlights?
Bumb
Old Feb 20, 2012 | 01:10 PM
backgammon7's Avatar
Car: '86 SC
Engine: 2.8
I may be wrong, but that doesn't sound possible with the factory bulbs. I dont think both have a high/low option. If you put in those aftermarket light fixtures that allow you to use more modern bulbs, then I think its possible.
Old Feb 20, 2012 | 01:57 PM
Engine: L31 350
You can, just have to pick up some hi/low beam lights
Old Feb 20, 2012 | 02:03 PM
Car: '86 SC
Engine: 2.8
I was thinking you wanted to use the regular bulbs to do it lol
Old Feb 20, 2012 | 02:52 PM
Engine: L31 350
I do.
Old Feb 20, 2012 | 03:10 PM
Car: '86 SC
Engine: 2.8
The regular sealed beam bulbs?
Old Feb 20, 2012 | 03:26 PM
Engine: L31 350
Yup. I found my thread, had the details and wiring diagram in ir
Old Feb 20, 2012 | 11:27 PM
Car: '86 SC
Engine: 2.8
Link? obviously i'm ignorant of something. I'd like to know more about this.
Old Feb 21, 2012 | 06:02 AM
Engine: L31 350
Yeah let me post it when I'm home, I'm on my phone right now
Old Feb 22, 2012 | 11:54 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
While you're at it, rewire both the high and low sides of the circuit to relays and make the headlights brighter by running off of the battery directly instead of all that wiring that can go bad between the lights and the switch...
Old Mar 7, 2012 | 01:54 PM
zzjakect's Avatar
Car: 1985 Z28
This sounds interesting. Any links to the process or diagrams? My headlights do not work at all, so i was going to rewire and this sounds like a good way to do it.
Thanks for any info you can provide.
Old Mar 8, 2012 | 05:53 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
if all four low beams are on people will assume your brights are on and flash you to dim your lights.
Old Mar 8, 2012 | 09:32 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
So flash them back. if your highs aren't on you're not breaking the law. well I'd check your local laws first, I know here you can have a Max of 4 lights on at one time
Old Mar 11, 2012 | 12:47 AM
zzjakect's Avatar
Car: 1985 Z28
Anyone have a link on the wiring diagram for this mod?
Old Mar 11, 2012 | 11:43 PM
zzjakect's Avatar
Car: 1985 Z28
Can you post the link?
Old Mar 11, 2012 | 11:48 PM
BT85's Avatar
Car: 85 Camaro Z28
I'm interested to see this to lol
Old Mar 12, 2012 | 01:43 AM
zzjakect's Avatar
Car: 1985 Z28
We know it is out there!! I've done several searches and searches and searches, and learned all about Firebird flip up issues. How about some info on the idea of rewiring the headlights. Please! Someone has done this successfully and I would love to see the process. Thanks for all the intelligence you guys provide.
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
