Electronic Hatch Pop in 84
Old Feb 24, 2012 | 11:51 AM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
I've searched around and found info on installing the later hatch popper (such as the ones in the later birds) but nothing about installing the ones from the later birds into a 82-84. I was wondering if I go to the junkyard and tear an assembly out of the one they have (1989 bird) if it would be a pretty straight forward install on my 84? Also, what parts would I need off it?
Old Feb 24, 2012 | 05:02 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Electronic Hatch Pop in 84
In order to convert from your "slam" hatch latch to a "pull down" latch you will need to remove the factory brackets used to mount the original hatch "pop" solenoid. Only then can the proper bracket from an 86-91 body can be welded into place.
Here is a picture of the original 82-84 unit:
Here is the 86-91 hatch "pull down" version:
Once that project is completed you would need to remove/replace the original plastic rear hatch trim panel with the 86-92 version so that the PPD hatch motor is properly hidden behind the panel. The PPD motor can also have an additional hatch "pop" solenoid installed with a button on the console (Camaro) or dash (Firebird).
Old Feb 25, 2012 | 10:20 PM
Car: 1984 Trans Am
Axle/Gears: Stock
So basically I need everything from the bracket back along with the switch from the dash to finish the job. Will the newer panel work with my 84 cargo cover though?
InfernalVortex
Apr 20, 2021 11:31 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Luigytico09
Oct 1, 2015 08:46 AM
anesthes
Sep 30, 2015 07:48 AM
formula00ra
Sep 28, 2015 11:50 AM
